Help
Jeeprockin1995
i got a built Kenne-Bell v6 mud dragster motor and its been out in the rain for about 3 years and was full of water and is now locked down anyboby have any advice
give it to me.
if the water has gotten into the bores and seized them then the engine is done. time for a rebuild.
A.j.
You locked it up for sure. Take it apart and put it on a stand and see if you can take the crank out. If you can rotate it so that the top of 1 side of the cylinders is facing directly downwards. Fill the bottom of the cylinders with a good penetrating oil and wait a week. If the oil makes it past the pistons rotate the other side and do it again. You might be able to get the pistons out now but it will need rebuilding.
