A pressure check is performed by putting a 0-300 psi pressure gauge in the 1/8-pipe port above the shift arm on the driver side of the transmission case. Make note of the min. TV pressures and the maximum TV pressures as well, in each shifter range.
Unsticking a valve involves removing the valve body and disassembling any errant valve assemblies for cleaning.
