help
82gn
hi any one have spark control module 82 buick turbo service number 1225401
hey u have more parts for the car i need compete the logo on the dash say grand national motor division mine is fade it:D
The I'm not sure about that number you have. In the link I posted, the numbers are different. It's going to be difficult to find. The '82 ESC module is differant than '83 and on. You may have more luck finding a used one from another 1982 with a 4.1 V6 (LeSabres or Rivieras most common). Problem is most people don't know they are under the dash, so you may need to find a complete car in the junkyard.
but mine 3.8 turbo 4.1 v6 are the same:confused:
Depends. There were two designs. If you have the later design, they have the same part number. (Check the table in the link I provided) If switching designs from first to second, you will want to swap the brackets as well.
I have never messed with the ESC on an '82, so I don't know from first hand experience. The '82 GN's were later in the model year, so maybe they are already the second design. I would look for the 16017464 number somewhere on your ESC module.
thanks
