Helpful info...found my "studdering" problem
savage6
After much labor and money wasted I found and partially fixed my problem! It turned out to be a cracked sending unit line. the one in the middle(the one that has the ground for the fuel pump in the tank) had come "un-welded" from the top. This allowed it to wiggle around and made for a bad ground under inital acceleration but after the "jump" it would pull fine...very confusing. After some soldering and JB weld it runs fine.
Thanks for the help! :)
Evan
savage im having a studdering problem, i just replaced my fuel pump, im thinkin mabye icould have a s miluar problem but i dont quite get what you are saying.
