1984 T Type. Pretty much stock and when I bought it, it is supposed to be all original. I figure the car has around 90,000 on it cuase I am having problems with the dash cluster, but that is another story. Car has a walboro 340 pump, and hotwired, has a Bosch 237 regulator and 2 1/2 exhuast oh yeah and a cold air intake. I have great oil presure and engine sounded tight as can be. Well it started blowing oil out the exhuast and it still had plenty of power I drive back to the shop and poped the hood and the turbo was bright orange
I am suprised the car did not go up in flames, as of now it is making a good ticking noise and it squels at the same time. I took of all the belts and it does really squel when it is running. It is coming from the drivers side of the motor so I poped of the valve cover to check out the rocker arms and the valve cover bolts were so loose it scared me. I also noticed the car has new head gaskets and intake gasket as well
So I know it has been apart before. I also noticed the spark plugs are so sirty from what looks like a rich condition!!! How can that be
I don't know where to start or if I should just pull it and go thru it all at one time. What do you guys think about it. I more or less worried about the squeling noise
