Where does this go? The grey wire is not soldered to anything right now. This is the little black box that comes with the update. I like to open things up and I am glad I did this time.:smile:
The new clear LED takes the place of the RED LED,I can remove this?
The wire coming off the top of pump at the switch with the eyelet on it goes to a chassis ground?Other side of the switch goes into the harness,when it gets into the dash this side is also grounded. The thick brown wire goes to this wire..so both sides of the switch are grounded...that doesn't sound right. I am confused Unless the eyelet goes to power....
