Hi flow pump, filters, lines, and tank.
Wknight13
SX fuel pump w/ pre and post filters. Also 5' and 3' braided hose (1/2" id). Works fine, just went back to internal pump setup for street. Also have tank retro'd for this hookup. Came off my 87 GN.
5' hose w/ fittings $75
3' hose w/ fittings $50
Tank $50
18201 EFI & Carbureted In-Line Electric Fuel Pump $200
Supports carbureted engines up to 1300 HP and fuel injected engines up to 1000 HP at 45 PSI. Ultra high-flow rates exceed: 80 GPH at 12 volts and 45 PSI, AND 120 GPH at 12 volts and 10 PSI. Flow-through design maintains maximum cooling, produces outstanding reliability, and provides consistent fuel delivery from idle to full throttle. -10 AN inlet/outlet fittings for easy installation. For use with gasoline or alcohol fuel systems. Passes UL standards for Coast Guard approval for use in marine applications. Fully re-buildable.
41002 EFI & Carbureted Slim-Line Fuel Filter $50
-10 AN Inlet/Outlet Ports,
Calibrated for all EFI and carbureted engines up to 2000 HP
Compact flow-thru filter design and enlarged ports will literally flow the maximum of whatever a -10 AN line can handle
Virtually no pressure drop [less than .15 PSI pressure drop at 200 GPH]
Easily connects before and/or after the SX Performance™ In-Line Electric Fuel Pumps
Quickly and easily install and remove aerospace fuel filter element
Compatible with gasoline and methanol.
JEGS Performance Products#555-150006 $50
Black In-Line Fuel Filter
· -10AN
· Gas and Alcohol applications
· 100 micron (stainless) filter
· 5" long x 1-3/4" dia.
fuel pump.JPG100_4235.JPG100_4234.JPG100_4224.JPG100_4225.JPG100_4226.JPG100_4229.JPG100_4231.JPG100_4232.JPG100_4233.JPG
Trades? Looking for a Scanmaster, new carpet, and headlight bezels (no cracks or chips).
Resurrecting this post in order that I have been just sitting on the tank since last post. Unfortunately shipping was to outrageous for the last deal opportunity. But I am still looking to sell the gas tank. Fort Wayne, IN
