High Current Fuel Injection???
I see an advantage when running low impedance type injectors that are run at high duty cycle levels.
It cant hurt..
hth
1QWIK6 said:
Why would my engine run richer?
because of getting a better duty cycle from more constant voltage to your injectors factory harnesses tend to give weak signals to some cylinders than others just like to hot wire fuel pump you will get more pressure after installing it
