high flow air filters
chevyII
What type of air filters wold you run with large frame turbos 5" intake. I see K&N make tapered round filters to 6 in diameter but are flat ended. I'm making a header to face the intake facing foward and moving the turbo toward the grill. Can you clamp a large filter right on the turbo?
You might try S&B filters at www.sbfilters.com They have six inch flanged filter, radiused flanged filters, and reverse cone filter ends. I just don't know if they combine all three in one filters.
Hope that helps
David
87GN
Thanks thats what I was looking for. a filter with the tip that flows air. K&N filters are all just a square end. I emailed them to see if it will collapse being minted right on the turbo inlet?
