Deejpig
- Aug 23, 2015
Looking for some suggestions to help diagnose what's going on with my car.
I recently changed to 60# injectors, added a RJC Powerplate, and had my stock throttle body cleaned and ported to 62mm. I also had my chip updated to reflect those changes.
The car starts right up after sitting for several hours, overnight, or for several days. It idles where it should, and seems to run fine. However, when I try to start it after I drive it for a few miles and it gets warmed up and I shut it off and let it sit for a little bit, it doesn't immediately turn over. I have to crank it two or three times, and when it turns over, it sputters a little and then the idle shoots up to 1800-2000 rpm and doesn't settle back down.
I've read/heard to look for a vacuum leak, but wouldn't that affect it starting all the time and not just after it has warmed up?
Any help or suggestions are appreciated!
