High impedence 80 injectors
The_Six
Hey guys looking for a set of the 80 High impedence injectors dont want to have to mod my ECM to use them. I do have a set of 60s to trade if some one was going to go to 60 from the 80s thanks
no ecm mod needed to run 80lbers. but you will have to step up in the fuel system with a in tank double pumper or external fuel pumps.with your 60lbers & single pump guys have gone high 10,s with no problems depending on youre setup.turbo,heads,cam,downpipe,converter,ect,ect.if goals are to go faster than that.a double pump & 80lbers setup will get you there.
Im only going to the 80s to have a little more room for running e-85.Im still trying to decided on my fuel pump.
