high stall converter question
wicked6
I am running a 3000-3200 stall ArtCarr NLU converter. I am experiencing intermittent stalling and thought that the IAC needed to be cleaned.
TurboDave mentioned this
You're running an Art Carr converter. Has your chip been modified for high stall converters? It's an anti-stall change that needs to be made because the reduced inertia of the high stall converters also allows the engine rpm to drop faster than normal.
How true is this and does anyone know what would need to be changed on my chip. I currently have a custom chip, not from any of the major vendors, but using a chip burning software and 12 runs from my car.
TurboDave is quite right here.
I'm not sure what the fix is in the code but it will help your stalling situation.
