High temp coating?
fatride
Senior Member
Has anyone used Bill Hirsch's 1800* hight temp paint? If so how did it hold up? Any tips on how to apply it?
I got the black! Thats rated at 1800*.
Dennis do you want to see the Carfax??
It's good stuff and holds up quite well. Best to scuff up stainless steel if that's what you're using it on or else it will flake and require periodic touch-up. For a look, Bright Aluminum version was used on the exhaust housing and dp:
http://www.geocities.com/joyof6/Engine2_2002.JPG
Nick shoot some pics of the black when you are done,I might try the Cast Iron gray...
Thanks Dennis
Dennis I might do it this weekend. I'll let you know. What did you think of the carfax?:confused:
Thanks for the replys guy's:)
