turbojimmy
Supporting Member
- May 26, 2001
I've recently started down this upgrade path that has of course snowballed into a ton of other things. Picked up a used turbo. It has a 4" inlet so I had to change my cold air kit (Mark Hueffman makes some really nice stuff, BTW). The 4" kit interferes with the IAC so I got an angle boss (nice piece, too, from John's Performance). Now the up-pipe won't clear the 4" turbo inlet so I got a Precision housing, which sits 5/8" higher than stock (I didn't want a spacer because with a power plate and a spacer there's a lot of gaskets).
So the question is: if you have a taller plenum, how do the vacuum lines reach the vacuum block? Seems to me that there's not much give there.
TIA,
Jim
TIA,
Jim
