TinysTurboPerf
RUTHLESS
- Jul 14, 2001
SCAN TOOL RESULTS ????
When I go to take off the car spits and sputters and you have to feather the throttle to get the car to even move. Then when you are going, it still wants to fall on it's face. You can feather the throttle and finally get it to go and accellerate to full throttle.
I'm getting fault codes on the scanner all over the place,
Faulty ECM, Coolant Sensor Too Low, No speed, O2
They come and go sometimes, sometimes not.
It has a new fuel pump and I tried another ECM and neither fixed the problem.
I installed a new trans a couple months ago and put the ground wire that was on a bellhousing bolt to the rear of the pass side head, today i installed some new star washers and put it back to the bellhousing to see if that was it, NOPE.
I am planning to check the resistance on the injectors to see if one is out of whack.
Fault codes shown 13, 14, 23, 55
O2 (mv) 400-440
RPM 1000
Integratr 128
Open Loop
TPS 40
Block Learn 142
IAC 16
Load/LV8 35
Airflow (gm/sec) 6
Spark Advance 37 degrees
O2 Crosscounts 14-27 fluctuates
Coolant temp 179 degrees
MAT temp 122 degrees
Does this shed any light on the situation????????
Any ideas would be a great help. Street Machine Nats are here this weekend and I would like to go without embarassing myself.
The fuel pressure does not drop off when this happens, it stays at around 40psi or above.
Thanks in advance.
O2 (mv) 400-440
RPM 1000
Integratr 128
Open Loop
TPS 40
Block Learn 142
IAC 16
Load/LV8 35
Airflow (gm/sec) 6
Thanks in advance.
