The last couple of times I drove my car I noticed it seemed as it has bounced off the rev limiter just as it was about to shift 1-2 at wide open throttle. It's not flaring, wheels are not spinning and it's pulling hard. The only recent change I had made was a taller tire 275/60 Nitto 555r and I also adjusted the TV cable the correct way. Both times it happened while I was annihilating my buddies newly acquired big block Camaro.
It's pretty cool lately too, temps in the 10 degree Celsius range. I also have Alky so I know this is not good as it will still be spraying and could cause a super lean condition. If I keep the pedal just off the floor, it's fine. I am leaving the shifter in OD or D. Trans is fresh last year.
Any ideas? could the cable be too tight, should I back it off one click. It's never done this before. My mods are in the Signature below. Extender Chip.
Thank You!
Thank You!
