I'm trying to connect an HKS Super Sequential Blow Off Valve but not sure how to connect it. I searched the forums and Google but with no luck (there was mention of an HKS on here but it apparently had two nipples on it and mine just has the one). I've tried all kinds of ways of connecting to vacuum and/or the turbo compressor nipple with and without a check valve but no luck. It holds vacuum when I tested it with a vacuum pump and I've loosen the top adjuster all the way up, which I assume makes it open easier. The HKS seems to work a little differently than most other blow off valves so it won't leak boost from a weak spring. Thanks!
