- Nov 11, 2017
HOLLEY EFI plug and play with CRUZ Performance engine harness for TURBO Buicks
CRUZ Performance has designed and developed a plug and play engine harness that will allow you to use the HOLLEY Dominator ecu or the HP ecu.The harness is a direct plug in for all your factory engine sensors and fuse box that will retain all your stock accesories.
The base harness is $650 and will only be sold with purchase of HOLLEY ecu from CRUZ Performance.The HOLLEY ecu gets its power and ground from 10 gauge wire that attaches at the battery.(this eliminates the voltage issues that other brand ecu's have when using adaptor boxes with faulty 30 year old wiring)
CRUZ Performance has designed and developed this harness to remove your 30+ year old weak stock cut up harness to only work with the HOLLEY smart coils (6 individual coils are needed).The HOLLEY smart coils are far superior than a stock ignition module or any replacement coil kits available for the turbo buicks.CRUZ Performance makes a hotwire smart coil harness that gets power directly form the battery.
HOLLEY Dominator or HP ecu's are self tuning with data logger and dedicated fuel and oil pressure inputs.
Holley ecu's feature (may require additional parts)
* boost controller
* boost bump
* Integrated water/methanol injection control
* Integrated electronic transmission control--currently can control GM 4L60E and 4L80E (Dominator only)
Most Turbo Buicks will only need the HOLLEY HP ecu to control the basic needs of everyday daily driving.For the Turbo Buick owner that needs an extensive amount of inputs and outputs the Dominator ecu will allow for limitless combinations of options that will be able to be used as a complete data acquisition system .
contact CRUZ Performance for pricing and all options
813-399-0409
don@cruzperformance.com
cruzperformance.com
* boost controller
* boost bump
813-399-0409
cruzperformance.com
