- May 28, 2001
SignUp Now!Sorry I'm new to all this but what is the advantage of this unit over the XFI??
So what’s the cost on all of that?I am very excited about this. So close on pulling the trigger. In my opinion it’s a bargain really. Let’s compare it to the gn-Ecu; with this setup you get a entire brand new harness, 6 coils and brackets, new sensors and I’m sure there are a couple more things. Even though it’s not quite an apple to apple comparison if you spec out a new harness and let’s say the tr6 coil setup you are still in the green. Now the debate on which software is better will never end. Don’t get me wrong I like what Eric has done over there at turbotweak but I’m ready for something a little easier to connect and tune with.
I just got this sytem from cruz, with the holley sensors for the water temp and oil pressure. Do I need adapters to get them in the buick block? If so can you tell me what they were? I havnet dis-assembled everything yet!
The HP and Dominator are two different ECUs.
The HP has 4 external inputs and 4 external outputs, the Dominator has 128 inputs and outputs and adds 4L80 trans control, that's the difference between the ecus. The software and functions are the same outside of the trans control.
The Holley kit for 3200 includes:
HP ECU
Full engine harness
Smart coils for COP ignition
Hotwire harness for coils
Plug wires
Startup program
That's everything needed for the conversion.
The only other item needed and not included is fan relay / harness, and that is dependent on the fan style used.
