Holley HP EFI + Cruz Harness Install
I have the dominator so I have more I/O than I will ever use. But if you are limited to 4/4 it's easy to use them up.
Some ideas
Outputs
1. Fan
2. 2nd Fuel Pump
3. boost+ (PWM boost control)
4. boost- (PWM boost control)
5. Transbrake/Bump
6. AC kick if needed
Inputs
1. Trans Temp (could go to dash if you have a it)
2. Flex Fuel Sensor
3. VSS
4. Alky PSI
5. Dial for boost :) (AEM 30-2056 AEM 12 Position Trim Pot)
6. Wheel/Driveshaft speed sensor
7. Coolant pressure sensor
8. Oil temp
9. Scramble button
10. Transbrake button
11. etc
Thanks This is good food for thought
Outputs
1. Fan. (YES)
2. 2nd Fuel Pump (proudly not)
3. boost+ (PWM boost control) ( I have a Turbo Smart I really like and understand)
5. Transbrake/Bump ( No)
6. AC kick if needed ( Yes)
Thats 2 of the 4
Inputs
1. Trans Temp (could go to dash if you have a it) (I have a Holley 5 in it dose not have any IO I'm almost positive ) ( Yes}
2. Flex Fuel Sensor ( no E85 in AZ Bummer)
3. VSS ( yes )
4. Alky PSI (Yes(
5. Dial for boost :) (AEM 30-2056 AEM 12 Position Trim Pot) (?)
6. Wheel/Driveshaft speed sensor ( I Have looked at them so maybe)
7. Coolant pressure sensor (no wouldn't know what I was looking at)
8. Oil temp ( never thought about it I tossed my cooler years ago because Dan DLS said no need)
9. Scramble button ( no not enough HP to try to find 100 more)
10. Transbrake button (No)
Thats 3 of the 4
VSS and drive shaft about the same Correct ?its can be used to see if its spinning and useful data down track.
