turbowrenchhead
Drive like you stole it!
- May 25, 2001
Well if you don't mind cutting the sh*t out of your car, go for it. The Ford i/c is huge. I didn't mind cutting the core supports but when it came time to fit the headlight assembly on the mouldings for the high beams had to be cut alot. I don't see a way of keeping the high beams at all. There is not enough room. I think I will get some dark covers for them. Where can I get those?
One more question, I forgot how the spring is installed to the grill to hold it tight. The i/c takes up alot of space, so if the springs were routed through there, I will have to think of another way.
I talked to Matt (cool84) and he had not put his headlight assembly on yet. Good luck Matt.
