I'm in the process of building a back porch patio covering. The roof is going to be flat with a 8" drop over 8 feet, and covered with rolled asphault/mineral roofing material.
My question is just how to secure this stuff at the edges where there is not going to be another layer over it to keep it from leaking thru the nail holes, if I am to nail it down?? (Actually I guess I have the same issue on one side of each roll laid)
I have some black plastic roofing cement I used on a metal roof building a while back to seal up nail holes...do I use this stuff and just cover up the nails used to secure the roofing and also on the seams??
I plan to put a layer of tar paper down
Then the edge flashing,
then the rolled asphault
then come back over the seams and nails with the plastic roof cement.
Is this correct or should the cement stuff also be applied under the rolled asphault to help secure it or is the nails enough if that correct?
