Hood mounted gauge brackets
TR Custom Parts
Mark Hueffman - Owner
Now have single AND double hood mount gauge brackets in stock. Powder coated steel set up for use with Autometer 2 1/16" #2204 gauge mounting cups. They have nut rivets installed so you don't have to struggle with wrenches while installing the gauge cups. Fits the contour of the hood nicely and screws to the flat surface under the hood. Holes are already drilled in the brackets for an easy installation. Not cheap but not cheaply made either.
Perfect for a fuel pressure gauge and you can use a double mount if you want to add a boost gauge next to it.
Made in the USA.
Click below to go to my site.
Hood Mount Gauge Brackets
Very nice! I dont think your price is out of line at all. beats trying to hack one together yourself. Keep up the good work!
dude I would've gave you double that in the time it took to bend and make mine...cause it's not a simple straight bend and it will fit thing. Nice!
