MNcarbturbo
What's Fuel Injection?
 - Mar 9, 2009
And the car runs like junk.
I stole a switch off my boosted 3800 project and finally put it on my car for a PECV/PEVR switch. I just have a switch that turns on at 3" of vacuume, a line coming off the intake for mainfold pressure, and a switch to block the boost pressure from making it to the power valve. So at 3" all signal is cut to the carb and the power valve goes full rich.
My problem is it runs bad from 6" to 1" of vacuume. I didnt have the switch hooked up yesterday so the power valve ran directly off mainifold pressure. I had the same issue. Runs worse than it normally does when cold, and when up to operating temp it bogs from that 6-1". If I keep it at 1-2" long enough it will pop out the carb, which Im assuming its backfiring. It runs 2000 RPM at 8", 1900 at 7", 1800 at 6", 1700 at 5" and so on until its running at about 14" at 1" and just is a slug. But once I go over 1" the thing comes right back alive and runs normally.
This never happened with the the power valve vented disconnected. No cold running issues, no poping, and definitly no flat spot in the carb. That is the one thing I changed and runs flat out bad.
I had the same problem last spring and the car wouldnt even think of running. I know the power valve stop height was messed with by the previous owner and at the advice of a local carb guy I pulled the plug above the top of the power valve and build an adjuster so I could play with that height. It doesnt make any difference where it is. Runs equally bad everywhere.
My question is, if that height adjustment is only for idle, why does the car run so bad at speed? I know its not right to run without the power valve but the car runs so good with it disconnected and so bad with it hooked up I can't think of whats wrong.
