Horn Contact Assembly- Where to Get?
Yankee John
I'm in need of the horn contact assembly located just under the rubber outer cover. This is the part that is two metal discs seperated with foam and has the wire coming out of it.
Does anyone know where to find this part?
The one in my car now is all bent up and warped (horn doesn't work because of this, but they do if I jump the contact plate to ground).
Thanks in advance!
John
Have you tried calling the guys at gbodyparts.com. He sometimes has extra parts like that. If not post in the parts wanted section. I'm sure someone here can help.
Good luck
