I did a pull with the powerlogger connected since I have been having issues at WOT. I would come into boost and it would pull relatively smoothly, and then all the sudden POP! For a split second it feels like im going nowhere. Target boost is around 23psi, but with that pop, i'm surging for that split moment up to 32psi. Before connecting the powerlogger, I had no idea what was happening since I can't watch all the gauges at once during my pull to see exactly what is happening.
I do not have an EGT or wideband connected at this time so pay no attention to those numbers. What I am looking for are a few opinions of what may be happening. The car is running the OEM 2.5" MAF, 80lb. injectors, a precision 66mm turbo that SHOULD be exhaling out of a Turbonetics Deltagate WG. Something is failing here. any ideas
My speculation after seeing that it blew the vacuum line off of my MAP sensor which is connected to the Alky system and I believe is also connected to the wastegate and that when that line came off, the wastegate slammed shut causing the boost spike. Is it possible that I just need to fasten that vacuum hose a little better and be good to go.
This is the last frame that everything feels relatively normal.
This is the next frame.
