Here is my list of parts this is with a -8 feed split to 2 -6 lines to the rails all Teflon hose. . I was going to feed the rails from the back and then run the front lines to the fuel regulator then run -6 line to the old 3/8 feed line to use as the return. For the feed to the tank I was going to run -8 as close as possible then reduce it to -6 so that I can clamp the -6 on the original feed line from tank I may end up making a new feed line with a-8 end welded on but haven’t made up my mind yet. For the return the plan is to flip a fuel filter over so it flows towards tank and then pick up some 3/8 to ¼ reducers from a local auto parts place.
fuel fillter SUM-230118R $70
Fuel Pressure Regulator PFS-10671 $ 106
Fitting, Y-Block -6 /-8 SUM-220108B $27 1 needed
Fitting, Straight, Male -6 AN to 16mm x 1.5 FRA-491971-BL $7 1needed
Hose, P.T.F.E., Teflon® Lined, Braided Stainless Steel, -6 AN, 10 ft. Length, Each FRA-601006 $39
Hose, P.T.F.E., Teflon® Lined, Braided Stainless Steel, -8 AN, 10 ft. Length, Each FRA-601008 $50
Fitting, Hose End, P.T.F.E., Straight, -6 AN Hose to Female -6 AN, Steel, Zinc Plated, Each FRA-600106 $7 11 needed
Fitting, Hose End, P.T.F.E., Straight, -8 AN Hose to Female -8 AN, Steel, Zinc Plated, Each FRA-600108 $9 4 needed
Fitting, Union Reducer, Male -8 AN to Male -6 AN, Aluminum, Nickel Plated SUM-220844N $6 1 neded
