So you truly didnt need to modify them?That would be a good way to start. The new manifolds are bigger diameter so I had trouble getting them in without removing the down pipe
I thought they needed to be cut and welded to fit properly?
SignUp Now!So you truly didnt need to modify them?That would be a good way to start. The new manifolds are bigger diameter so I had trouble getting them in without removing the down pipe
I have a set but havent installed them yet. So im interested to see what you needed to do for the downpipe.I'd like to spread some insight on this subject. I have an 84 gn that had aftermarket headers on it that were warped so I bought these 190$ ebay specials and installed them in the car Saturday. My car is an a/c car minus the compressor so I have the big stupid box. The whole job took me 4 hours but I've been in every nut and bolt on my car. Headers were good quality with thick flanges and came with nice gaskets. Drivers side header slipped right in. To remove the passenger side header and fit the new one in I removed the alternator and the bracket off the head. Headers fit nice. I will say the 02 sensor is a C hair from the bracket and I don't have the compressor.
The crossover pipe was a BITCH. Passenger side flange could not be in a worse spot and I had to trim the 2 piece design down in the middle to mate the driver's side. Again these are 190$ headers so it's to be expected.
Here is my problem. I read this thread before purchasing and everyone neglected to comment on the down pipe. Mine didn't fit! What down pipe are you people running because I had to make one. Maybe because it matched the headers and up pipe that I had but because the design of the new up pipe on these new headers I didn't have enough 90 degree and had to butcher it up.
I can't pictures to upload so I will get them up later
Your factory downpipe didnt fit?
I have studs on mine exhaust pipes. I heard the up pipe might be a tuff one. Haven't got that far yet.
Did you replace the threads in to the turbo? I have a feeling Iam going to break these when I do this upgrade, thanks for photos.i got the clamps from napa. I believe i used the 3" v band clamps. And a 2 1/4" slip clamp for cross over pipe. I have the part numbers written down at work. I'll post them on here if I remember to look them up
