SignUp Now!Try ATR they do exhaust for our cars and Poston still has a few parts for our car. If you do a search you can find out where to go or pm me and I will be more then happy to help you out.fbodlovr said:Where do you guys get most of your parts for your cars? I seem to see downpipes and everything for the 86 87's, but not our cars.
buickpower said:The TA33 flows ~660cfm, the stocker flows ~390. You send your stock turbo to John Craig at Limit Engineering, and he mills out the turbine and compressor housings and installs larger wheels, so the turbo looks externally stock and bolts up the same. Cost is about $785. I believe John will still install larger guts in the same housing, but I am not positive nor am I sure of the size.
buickpower said:turbo6x2:
I assume you were referring to me in your post. For the record, I made it abundantly clear that there was "nothing wrong with" your build. Also, where exactly did I call myself an expert? I am not, nor have I ever claimed to be, this is the reason I put "FWIW & IMHO" at the top of many of my posts, and often invite the more experienced to fill in where I cannot, as can be seen twice in this thread alone. I was just trying to give what I feel is practical advice to a newcomer. As to your build up, how are we supposed to know exactly what size turbo you have? We only have the buildup you wrote about to go on. And to me it doesn't matter as to the reason why you put your parts on, that's a moot point, because the mods are there now.
To me, "doing it right" is something that is totally subjective. It will vary based on your goals. Does this mean that for a person that wants a reasonably quick street car (read: AVERAGE CAR, not in the 11's), an electric water pump and oil evac system is required to "do it right"? Those are just examples of course.
I would like to make it abundantly clear that I have no beef with you whatsoever. Hell, I don't even know you. All I have to go on is what you have written about your build. Your car is very fast, one of the single fastest hotairs in existence. By very definition that makes your car above average, and for this you have my respect, and i'm sure the respect of many others. This is why it is confusing to me that whenever your build is mentioned, you seem to go on the defense. That's not necessary, IMO because your car's speed speaks for itself. Also, I am confused as to why you, as in past posts, brought up the fact that you are a woman. That was not even mentioned here, and it is totally irrelevant and had no bearing on this discussion. You have nothing to prove here, people will respect your accomplishments regardless of your sex.
Regards,
Mike
FWD turbo said:I just recently went through this myself, so I can give you some specifics as far as what is currently available. Right now, the TA33 is the biggest upgrade available from Limit - assuming that you are going to stay with the stock housings. Precision can make it into a TA48, which flows I believe 750 cfm, or they can go bigger if you want them to. Tim at Precision built mine for me. He put in a 60-1 compressor wheel and T31 turbine wheel. He says it should flow about 840 cfm. According to him, that is the best possible flow you can get out of our smaller hot-air housings. If you want to stay with the stock housings for the stealth (which was very important to me for various reasons) those are pretty much your options. And you do need to send them yours for a core. But if you don't mind doing some fabricating, you can put pretty much any turbo on that you would like too, as long as you have the supporting mods. If you decide to intercool it, you are looking at some fabrication anyway, so putting in a turbo as well with a different housing might not be a big deal for you. I don't know you or your situation so I can't comment on that one. I hope that helps you some. Good luck.
FWD turbo said:Here are some before and after pics of my turbo. You can see a HUGE difference.
