Hot Air T-Type Assist needed
edfiero1
Hi All,
New 84 T-type owner here.
A couple of starter questions.
1. Can anyone identify the connector in the photo? I found it disconnected.
2. The vacuum lines in this car are a real hacked up mess. I have looked at the vacuum line routing that appears in the Factory Service Manual, but its not totally clear where all the lines go. Does anyone have a different drawing other than the one from the factory manual, or have some close up photos of all the vacuum lines they could share?
The car is currently spark knocking real bad. So as a first step in trying to get to the bottom of that I want to make sure all the vacuum lines are connected properly. If this doesn't help with my problem, expect more questions :)
Fuel pump jumper
In studying the picture, it looks like there is a hose nipple at the bottom of the throttle body with nothing connected to it. What goes there??
Could be the old cooler line .not used
Sent from my SM-G920T using Tapatalk
Read below for proper terminology. [emoji116][emoji116][emoji116][emoji116][emoji116][emoji116][emoji116][emoji116][emoji116][emoji116][emoji116][emoji116][emoji116]
Throttle body coolant line port
