Hot air upgraded turbo charger by work turbo
I can help you if you want new but be warned a 62mm compressor wheel won't leave much left to the diffuser on a stock turbo. You'd be better off using an 86-87 cover. Welding the adapter to the compressor cover outlet would be required
What about the proper carbon seal? Won't a 87 turbo leak oil?
No because it can be built with a carbon seal like it was from the factory. I can go up to t04e in carbon seal. T04e will get the full flow out of the compressor but would require modifications for clearance and you'd have to adapt the outlet somehow
