1dollardog
Are we there yet?
- Jan 5, 2007
Is there anyway to "hot wire" start these engines? I seem to have power to the ignition, starter and the ecm but nothing to the module, coil, and intern nothing to the cam sensor and injectors. Readings in and out of the ecm are ok. I've replaced almost every main componant,fuses, ecm,coil,module,cam sensor,crank sensor and someone told me it had to be a bad wire somewhere in the harness so I have just replaced it (not easy by the way) and still the same problem. Is it possible that the fuse block is bad not letting power get somewhere it needs to go and if so can it be temporarily bypassed to get power to the module and start it that way? I just need a temporary fix that would give me more options on what is really wrong here.
Thanks in advance.......
