Last winter I bought the Hotchkis Susp F+R springs 'cause mine were worn out. I have also recently replaced the shocks and struts.
After a complete front end rebuild (Moog: ball joints, tie rods ends, links, bushings, idler arm etc) I installed the springs. The rear sits way too low now...and the front sits way high on the pass side. I have to rotate the spring on the pass side so it is seated correctly (I installed it wrong) but it is sitting so high that I have doubts that will cure the problem!
I also have Southside Machine bars installed. I have not reinstalled the anti-roll bar or front sway bar yet.
Any suggestions???
Any suggestions???
