Hotwire Kit?????
UnderdogGN
Hi, I need a little help. I recieved a walbro 340 and hotwire kit as a gift from PTE last christmas, and im going to install it this weekend. Are there 2 different hotwire kits, 1 for the 86-87, and 1 for the 84-85???? If there is, how do you tell which one you have???
sorry if this is a dumb question
thanks
try this
try this- i just installed mine and was very easy
Turbo Buick High Performance Fuel Pump Assembly and Plug n' Play Wiring Harness
Walbro GSS340M
Fuel Pump with new in-tank wiring harness
and custom installation kit
RX-G75-FPA
Walbro GSS340M
RX-G77-FPA
Fuel pump installed with G77 system.
Order the G75 pump system if your sending unit has this connector with a black, pink and tan wire. This connector is located driver's side behind the rear bumper. Typcailly found on 1984, 1985 and some 1986 Turbo Buick's
G75-FPA + Hotwire Harness
$159.99 *
M.S.R.P. $179.99
Order the G77 pump system if your sending unit has this connector with a black, violet and gray wire. This connector is located driver's side behind the rear bumper. Typcailly found on 1987 and some 1986 Turbo Buick's
G77-FPA + Hotwire Harness
$159.99 *
M.S.R.P. $179.99
Fuel Pump Kit
Walbro GSS340M 255L/hr High Pressure Pump
Filter sock - 30 micron filtering (factory=70 micron)
Walbro to GM direct power wiring (no adapters)
High pressure fuel line
Stainless gear clamps
Rubber Pump Mount
Pump sound insulation sleeve
O-ring Tank Seal
Pump test lead
Upgrade / Hotwire harness
click for more information
Limited one year warranty on pump
Why a Racetronix Fuel System?
The Pump
Walbro Fuel Pumps have set the industry standard in high-performance. Walbro pumps are QS9000 certified and are used as OE equipment in many production performance vehicles such as the C5 Corvette. Walbro's gerotor design is able to maintain high pressure while providing high volume as well. This is done by squeezing the fuel out between two gears instead of pushing it like most factory vane pumps do. (i.e. factory TR pump). This positive displacement design makes high-performance Walbro pumps small, light weight, quiet, efficient and reliable. The Walbro GSS340M's armature is more efficient than the GSS307M's which allows it to flow more fuel at higher pressures with less current draw. The pressure setting of the GSS340M's internal bypass valve is set higher than the GSS307M's. The Walbro GSS340M is recommended for Turbo Regal's as it is not uncommon for the fuel pressure to approach or exceed 60PSI which is the recommended cutoff point for the GSS307M. The GSS340M is the perfect pump for serious performance minded racers and is capable of supporting high fuel volumes at pressures exceeding 60PSI.
Walbro has introduced the F20000169 to replace the GSS340M in March 2004. The F20000169 is exactly the same pump as the GSS340M apart from the new smaller offset molded inlet. This new inlet saves Walbro the trouble of machining the ends in order to accept a GM style filter sock. Walbro has priced the F20000169 slightly higher than the GSS340M. Racetronix will continue to offer the GSS340M by machining pumps in-house while passing the savings along to our customers.
Pump Installation kit
Walbro discontinued the 400-835 pump installation kit which wnt along with the GSS340M pump. Racetronix viewed this as an opertunity to improve and expand the components that were supplied with the 400-835 kit. Racetronix has added a pump sound insulation sleeve, power test lead and new in-tank wiring to the kit. The factory pump came with a sound insulation sleeve but this was never part of the Walbro 400-835 kit. This sleeve helps reduce pump noise heard from outside tank. The new test lead allows the pump to be powered up without the vehicle running in order to aid in draing the tank. This test lead comes in quite handy when changing pumps or fuel at the track. The test lead has an aligator clip at one end which attaches to the alternator's + output. The other end has a male push-on terminal which plugs into the black factory fuel pump test connector just behind the alternator. It is a handy piece to have in the glove box. The most important addition to this kit is the all new in-tank replacement wiring. <BELOW>
In-tank Wiring - Racetronix Exclusive!
In-tank wiring is quickly becoming a major problem due to the age of TR's. Many terminals are heavily corroded or broken off. The standard in-tank wiring that comes with a Walbro pump is an inline adapter. This adapter relies on the questionable factory wiring, adds another connection and length of wire.
Racetronix has used its in-house design and manufacturing facility to produce a one-piece replacement for the in-tank pump wiring. Racetronix replacement in-tank wiring plugs directly into the Walbro pump and into the factory bulkhead connector thereby eliminating all the factory pump wiring. Racetronix took the design one step further by providing a redundant ground clamp for the fuel module which has a factory bonded ground wire. The Racetronix harness is made from mil. spec. silver plated Teflon (most resistant to gas) wire and all connections are crimped and soldered (factory wiring & Walbro adapters are not soldered). There are no wires to cut, crimp or splice. All connections are Plug & Play.
The Wiring Harness aka 'Hotwire harness'
Racetronix
If an item is not in stock the payment link will be inactive - no need to ask about availability.
All payments processed securely on-line only.
Sorry, no phone orders. This is a web based offer only.
(Phone orders can be placed through authorized Racetronix dealers - pricing may differ)
Quantities are limited. No substitutions.
For other quantities please contact sales@racetronix.com
All sales final. No refunds.
Shipping and insurance fees will be added to your purchase for Xpress Post Service with tracking.
(Xpress Post service provides a 2-7 business day average delivery is location dependant)
Upon shipment of your order a tracking number will be provided.
Most orders ship the same or next business week day.
The hotwire kit works for 84-87 Turbo Buicks. It is all a matter of which side the alternator is on and that will determine which side of the car you route the harness down. It is an easy install, just follow the instructions.
thank you for the replies both of you. I was just worried that i might have the wrong hotwire kit and it wouldnt work, but now i know.
thanks
