Hotwire project diagrams
larry33kc
I am wanting to do some Hotwire projects ( headlight, fan etc.) can someone send me any wiring diagrams please. TIA
Also, if you need the factory wiring diagrams, I can copy and send them to you.
No I dont need the factory wiring diagram, I need info on how to hotwire the fan and headlights for better performance.
Thanks gofstbuick for the response
Use an insulated terminal box on the inner fender and supply power to it from the battery via a 4-6 gauge cable and a battery extender post.
Mount a relay for each item to be powered on the inner fender and run an 8-10 gauge wire to the relay and from the relay to the item being powered. Trigger the relay with the existing power wire that normally supplies the item.
Beef up the existing ground wire that goes to the inner fender.
You might check this link and see if it offers diagrams as well.
http://lighting.mbz.org/
