You probably have serious highway gears if your're running those rpm's at 65-70, but does it sound or rpm like its shifting down to 2nd if you mash it? If you manually force it down to second when you mash it, is it the same? Might be your kickdown cable on a th350.
Are the lock-up 350's supposed to unlock if you floor it/downshift?
