BRAD_PADGETT
- Jan 22, 2004
I need to raise my TPS volts at WOT. How do you do this on a hot air? Thanks- Brad
SignUp Now!Same way as an IC car. If your TPS reads too low @ WOT, loosen the screws and pull UP on the TPS. Lightly re-tighten the screws and set your closed thottle TPS setting. Go back and read WOT setting again.BRAD_PADGETT said:I need to raise my TPS volts at WOT. How do you do this on a hot air? Thanks- Brad
Add some excitement to this board and keep it alive! :biggrin:BRAD_PADGETT said:......... If there is interest I will keep the thread alive.
Brad,BRAD_PADGETT said:.......The car doesn't want to shift gears.
BRAD_PADGETT said:I have to admit that I am clueless here. Where is the TV cable? What does it do? How do you adjust it? Thanks-Brad
