Blowthrough build repeat.
Car is assembled again, it will get fired up tonight after some coolant is added and set the ignition timing.
Had to install 2 new motor mounts lol
Buick is alive again and no oil leaks yet yay! 😄
There's a new fuel leak to address though, it's one of the injectors so I probably disturbed it or o ring failure. That's acceptable for the 2 years the car was down and mice taking up residence in the tail pipe
I like that is cam is similar to stock and easy on valvetrain parts and better for iron heads that don't flow well and keeps rpm down.
Are your heads ported? I have ported with oversized valves on the 3.8 and champion irons on the 4.1 .
Buick hasn't left this garage yet.
Testing the Alkycontrol system and found a leak on the updated filter and pressure switch assembly. Unfortunately came from Alkycontrol like that I didn't build it.
Easy fix though 😄
Soon, Test it for leaks again after repair and lower the boost and finally go for a drive!
Brand new alky pump head from Razor! Ready to go now, just need a few nice day's before 2025 is over for testing lol
