I used a degree wheel and a piston stop. I fabricated the piston stop out of an old spark pulg and a bolt that would fit inside the metal part of the plug, after I broke out the center part, and extend into the cylinder, an inch and a quarter or so, then welded it into the plug. Be sure the piston is no where near TDC and put the piston stop in #1 plug hole and with all other plugs out, GENTYLY rotate the crankshaft unitl the piston touches the stop....again...GENTLY. Record the reading on the degree wheel, now rotate the crank in the opposite direction until it touches the stop again. Record the reading.....now, exactly half way, between the recorded measurements is going to be the exact TDC. Don't forget to grind the end of the bolt, round, just as a precaution, so it doesn't scuff the piston.
