How do you keep your balls up?
CHARGED
Check balls that is:D Doing PTS's shift kit with the trans in the car and was wondering what is used? thought I heard vasoline?
Vasoline wasn't thick enough for me.I used Mobile 1 grease that I had near.
I too have used vaseline in the past. Recently though have been told that transmission assembly lube is best (will disolve and will not effect seals). I just completed a rebuild and that is what I used. Go to a trans shop and beg for a little grease in a cup.
Mitch
Its called transmission assembly lube and is often Blue in color. If you are really that anal...;)
Boy, balls,anal and vasiline mentioned in the same post :confused:
What is this site turning into? :D
Stick your balls to the spacer plate and then put it up on the trans. :)
