How do you remove a/c dye?
John Larkin
Sublime Master of Turbology
I had dye in the a/c system to show the leak. Now that I've found the leak, how do I remove the dye where the leak was so I will know if it leaks again?
They have dye remover at parts stores. I just put rags around the the area and use brakeclean and it works great.
^^^ What he said.;) Make sure to spray it liberally to remove all oil residue and use a black light to make sure you got all of it.
