SignUp Now!The white/light blue plastic that everything is mounted to is loose, I removed all the bolts. I can move everything a little but I'm afraid to pull it out and ruin the harness or something.Take the plastic surround loose behind the cluster also. Then will help with the harness. Then take the little screw loose at center of cluster. Then I think a light socket on far right. Pop hood as u are working the cluster push the cable to give little slack to un hook. By taking the surrounding plastic loose it will help to work to get to the harness plug if it has never been out. It was s PITA . Maybe my not so good instructions will help. Good luck
How do I unhook everything? Does the harness have enough play to pull out the cluster bolted onto the white/light blue plastic(in picture)?dont forget the speedo cable is hooked to it also.
How do I unclip the tranny linkage wire?Look at this riviera cluster it should come off like yours
take a tiny screwdriver and gently bend all the connectors out a little bit, then clean the contacts with a soft pencil eraser, followed by some rubbing alcohol on a q tip..
