SignUp Now!Wow I didn't think they could go that fast with the stock injectors!! Cool now I have something to shoot for!
If anyone can give any suggestions I'm listening but I'm certainly not near 11's yet.
I dont know how your chip is setup or if it's adjustable but if not you might want to talk to Eric Marshall. When I used to run stock TTA's around all I knew was thrasher chips and they worked great but I'm sure a turbotweak chip would have worked better. How much timing does your chip have?]
13.11 @ 107mph sounds like you need a tire on the back, but the mph seems about right for pumpgas and 17psi of boost on a stocker. I used to run 12.7 @ 107mph on pumpgas with drag radials and 17-18psi of boost. I never had directscan back then, only a scanmaster so I dont know what my duty cycle was but I know there was enough injector with the thrasher race chip to keep the O2's around .770 at 22psi of boost on my car.]
Here's my old cars combo and what it ran
http://www.turbobuick.com/forums/turbo-trans-am-tech/109292-track-times-tta-861-a.html
You can check timing by looking at the spark advance on the direct scan.
Jason
O.k., at idle my spark advance shows 23.6 at WOT at 20.4. Is that a lot?
Sorry Kma967 for poaching your post but I sure have been learning a lot these past few days.
Thanks for the help!
That is pretty normal...If you don't knock, you are fine.
Jason
How in the He** did you get 15-16psi with a stock torque converter? What RPM? I don't have a line lock or trans brake.
Cannot count on that pump to push the fuel needed after all this time as well
Pump, injectors, hot wire kit, turbo tweak chip and check the valve springs. Don't add anything else(turbo, tc, etc).
could use a straight edge to measure how far each rocker comes up when you turn the motor over by hand. Only way to do it unless you wanna take em out and measure them.....
There is no way I am going to pull each one out and then put them back in. Springs are cheap enough that I'll just replace them. Probably next summer. Although as long as I'm replacing valve springs I might as well just install Champion aluminum heads right?
