I think I have a good setup for straight pump gas, but I'm not sure how fast I should expect to go. I would like high 11s at about 115 mph, but that doesn't mean it will happen. Worse case , I will call Jack Cotton after Xmas and get a BB T70 to get the job done, but I was wondering what should I really expect. I'm able to run 18-20 psi in 50-60 degree air without any knock up until about 105 mph and then when the converter locks, I get about .7-1.5 degrees. I tried locking it earlier, but the boost climbed to 23 psi and I would get about 4-5 degrees of knock so now I run it unlocked until over 100 mph.
The other problem is the rpms only drop from 5500 to 5200 on a shift so I'm sure I'm blowing through the converter a little bit. I will probably have it tightened a bit to make a little more efficient, but boost comes right up with it the way it is. Anyway, any ideas are appreciated.
