How hard is it to install a boost controller?
TurBo BiRd
Strong Islander
I want to know how hard it is to install a boost controller in my car. I just want to put in a simple one w/ a knob inside the car. Thanks
Takes all of about 5 minutes if your using a bleed of type valve. Take the vac line off your boost solenoid and run a the hose inside the car. Push the valve into the hose and boom adjustable boost. Just be careful they can be touchy and its tempting to turn the wick up a little to much. Atleast it is for me. :D
p.s. Leave the wire harness pluged into the boost solenoid or it will set a code in the ecm. Make sure you have a scan tool if you go this route.
Boost control?
Suggest you do not vent the control into the interior of the car.
If there's a backfire/ engine failure, the blast will come into the car.. could cause a problem.. Suggest you vent the open side of the valve back into the engine comp.
Also could just cause a stinky smell, depending on how much boost you bleed off!!:D :D
WOOOO!
sound easy enough to me :D When i get to doin it I may have some momre questions. Thanks alot guys ;)
Yeah I forgot the part about putting the vent side back into the engine bay. I ran mine both ways and the whistle from the valve can drown out the radio at times. :eek:
