How many miles can you expect from valve springs
Springs are like other parts they can and do go weak and they DO break. As Brian (Bison) stated he has done this and that with different springs but you can take it to the bank he has tested pressure on ALL of them and gets them set up at the right installed height. Plus knows what pressure he needs for givin cam set up.
Turbo -T above, it does sound like you are floating at 4800. I had one stock cammed engine do that exact same thing every time right at 4800 and it was the springs. I was floating the valves. When checked on a spring tester, they were about 55 to 60 closed and right at 160 open. About 7 years ago I had Al Dicksen at HRD ( a well know cylinder head guru who has never done anything in his life but cylinder heads) Use to even do heads for NASCAR and the likes. Anyway he redone a set of Champion irons for me and installed ALL Ferrea valve train parts, with spring locator cups, titanium retainers, the whole bit. I ran them on a 109 engine with forged pistons, stock turbo crank, polished stock rods, biller main caps and a 206-206 billet roller cam with spring pressures at 140-145 closed and right at 340-345 open with a 1.750 installed height and all the other supporting junk. Ran the hell out of it for 32,000 miles and it would pull hard to 5400 - 5500. NO problems what so ever (except had LOTS of trouble with those junk comp. cam roller lifters) went to the new Morels as soon as they came out. Built a new forged, girdled 109 last winter, took the heads back to Al for a freshening up and a good check out. We tested ALL the Ferrea springs and they were all still within 5 to 10 lbs. of original pressure. Now one thing I use to do at Al's advice, when I put the car away for the winter and it was just going to sit for several months I'd unload the springs. In other words I'd unbolt the rocker arm assembly's so they had no pressure on them. Put the freshened up heads on this new engine and with only acouple thousand miles on it was just putting down the street at 35 mph and just like someone flipped a switch it went to running on 5 cylinders and had some clacking in the valve train going on. Was real close to home so babied it home and pulled the right valve cover and Bingo!! busted valve spring. So just goes to show you parts even springs just wear out. Fatigue, bad spring ? Who knows. Throwed new springs in it and It's still running great. Oh cam is now a 210-215 ductile roller from Mike. I'm sure Brian can tell you ALOT more story's about springs than I but if you have dought pull the springs off ( not that big of deal) if it is a big deal to you,( LEAVE it ALONE) and get them checked out but you'll have to know or check your installed height.
Here's a pic. below of busted spring.
Yup. I can tell you that back in the mid 90's i didnt check spring pressures and most of the time i was ok. Then i had what i thought was a valve float problem after talking to the builder/vendor he assured me it wasnt. Well it was float and one of the 12 springs was definitely a different part number and was installed at about 85lbs on the seat. The rest wound up being about 120 on the seat at best. The engine needed about 140 on the seat. Lesson learned. Check everything then check it again. Ive seen a few broken springs in my time. I also have a set of early comp 26918's that many had failures with last a long long time. Like 30,000 miles and the engine pushed the car to 10.61/128mph at the end of that 30000 mile binge much of which under power was 25-30 psi/5000+rpm. Probably thousands of hits. Was it the very conservative 212 cam i had ground. Probably. It was under .500 lift at the valve even with 1.65 rockers. I never tested the springs after retiring that engine. The springs are still on the heads. Maybe ill check them when im bored. Fast ramp hyd cams need more seat pressure than the comp cams card may suggest.
this is a very helpful thread. My car pulls like a freight train up to about 3400-3500 RPM then it falls on its face, and shifts at 4900 sometimes and 4500 other times. I've been chattin it up on one of the other boards and concluded that the valve springs most likely are shot. Rebuilt tranny, properly adjust TV cable, etc. Thanks for the input gents
Yup,
I agree 100% there Scott. In past years I also saw LT-1's all over the place as far as pressure and Brian I was also guilty of that in the past NOT anymore.
what type of ignition system ?
It's a factory like set up, the coil is a Highway Stars hi-po unit. Plug wires are Magnacor 10 mm wires. Plugs are AC delco CR43TS's. I had NGK's in there before with the same problem.
I would change springs and verify pressure/heights since you don't know what's on there and you have symptoms of a spring pressure problem
Thanks. Is there any special methods/tools to setting up valve springs? And how/what do you use to verify pressure/heights?
Installed height checker, shims, and a spring tester. They have some that can be used in a vise to check seat pressures.
back in 2004 ANS machind my engine and pete said he put lt1 springs in my heads but he didnt say it was the 1970's lt1 or the 93-96 lt1 springs.
I don't know if i ever asked about recommended valve springs. My cam is listed in the signature.
My $0.02...
Back in the late-90's and 2000, I was a valvetrain release engineer at one of the OEM's. The engine we were developing at the time was having problems with valve springs breaking (and other problems related to valve spring harmonics), so I got to know valve springs and the process used to make them very well. During that time, I spent time at all three of the major US valve spring manufacturers (Peterson, Associated, and Mubea). At that time, if you bought a valve spring from anybody (Comp, Crane, or an OEM), it was almost certainly made by one of these three companies, and likely made in the USA or Europe. Now, a lot of the manufacturing has been moved to Mexico and other countries, and I would guess that there are now Chinese companies putting their products in the market.
A couple of things I learned that are worth passing on:
1. If the valve spring is made on an automated, modern process, it will not "sag" or lose load over time. If the spring is made on a good process, it will be "heat set", meaning it will be compressed to a certain height and then baked in an oven (simplified description). A spring that has gone through this process will lose very little if any load over its life in an engine. Note that heat-setting was a relatively new process to use in OEM spring manufacturing even in the 90's - the springs on our original 1987 engines probably didn't have that process, which is why they tend to sag over time.
2. In most automotive industries, stuff sold to the "aftermarket" is not made on the same processes as is used in OEM. I currently work for a bearing company, and I can tell you that the specs for a bearing used for an aftermarket alternator (for example) are different from a bearing to be used in an OEM alternator. Valve springs are no different. So, I can't guarantee that those Comp or Crane or whatever valve springs are produced to the same, modern processes and specs as an OEM valve spring would be made.
3. Proper valve spring design does not depend only on load. At a certain RPM, a certain amount of valve spring load is needed to ensure that the valve doesn't "float" (lifter loses contact with the cam) as the valve changes direction from opening to closing. That amount of force is a function of how heavy the valvetrain is (valve, locks, retainer, rocker arm, pushrod, lifter), how aggressive the cam is, and how fast the cam is rotating. However, as previously suggested, look up some videos of valve spring behavior at high RPM (they are out there on YouTube). All valvetrain systems have harmonics, meaning they resonate at natural frequencies. Think about ringing a bell - when you strike the bell, it vibrates at a specific frequency, producing a tone. Valvetrains and valve springs do the same thing. If the valve spring is "ringing" (resonating) at a frequency that corresponds to the cam rotational frequency, bad things can happen. Increasing spring pressure can help mask these problems. Other ways to help are to increase valve train stiffness (larger diameter pushrods, stiffer rocker arms, etc.) or decrease valvetrain weight (hollow valve stems, lighter rocker arms, bee-hive springs that allow for a smaller retainer, etc.). Either the above will tend to move the natural frequencies of the valve train higher, hopefully above the operating speeds of the engine. Of course, the natural frequency of the valve spring itself isn't affected by any of the above - that's simply a function of the geometry (size and shape of the wire) used to make the valve spring. The natural frequency of the valve spring itself can be mitigated by using thinner wire and/or a multi-rate spring (coil spacing is different at the bottom than the top), but this has the side effect of increasing the stress in the wire. For modern, lightweight, multi-rate bee-hive springs, special materials like chrome-silicon-vanadium wire are often used If you don't have complicated software to model valvetrain behavior (who does, really?), then sometimes good ole' trial-and-error is needed to pick the right valve spring for a given cam and valvetrain system.
4. For most engines, the valve spring is the most highly stressed component. When a valve spring is compressed, the stress in the wire is very high - higher than in the connecting rods, crankshaft, or anything else in the engine. That's why super-clean exotic steels like chrome-silicon and chrome-silicon-vanadium are used. A valve spring sees what we call "cyclical fatigue" - every time the cam comes around, the stress in the wire goes up and then down. (Think of bending a coat hanger and then releasing it over and over again). Because of this, all valve springs will eventually break if they run long enough (rarely is the stress level low enough for the steel wire to have "infinite life", especially at high RPM's). Properly designed, the valve spring should easily last "the life of the engine" in an OEM application. However, for the big cams that we sometimes run, I wouldn't expect 100,000-mile durability.
5. Valve spring dampers can be your friend - On the stock valve springs, there is an internal ribbon-looking spring inside the main spring (IIRC, haven't seen mine in ten years). That is not a "helper spring" - it's a damper. It's purpose is to help remove some of the coil "ringing" that occurs when a valve spring is running near one of its natural frequencies. If the coils start to "ring" and vibrate back and forth after the valve is closed, the friction between the coils and the damper will dampen the vibrations out. The goal is to remove all of the coil "ringing" before the cam comes around for the next lift event. Dampers can do this quite effectively. On the downside, dampers increase valve train friction and can themselves break if not designed properly. There are different types of valve spring dampers. Some are the "ribbons" I described above. Some are "cups" that go inside the valve spring and expand outward against the coils. Some are "cups" that go outside the valve spring and expand inward onto the coils. BTW, the engine I mentioned at the beginning of this post eventually went into mass-production with internal "cup" style dampers made of plastic. Interesting.
Here's a typical video of valve spring behavior at high-RPM. Notice how after the valve closes, the coils in the valve spring are still "ringing".
If the ringing is bad enough, then the valve can bounce back off the seat after it's closed or float over the cam nose when it's open. Both are bad and can cause erratic engine operation, particularly at high RPM. The two basic ways to "fix" this are to increase valve spring load (higher valve spring load will keep the valve planted even if the coils are ringing) or to "tune" the valvetrain better (with different valve spring design, lighter weight, higher component stiffness, valve spring dampeners, etc.). In the perfect world, "tuning" is better, since higher valve spring loads come with their own problems (such as wiped cam lobes or worn-out roller bearings on lifters). However, since we don't usually have access to high-speed cameras and valvetrain modeling software, we have to make do.
OK, the onslaught of relatives looking for Christmas dinner is coming. Hopefully somebody learned something, and Merry Christmas!
A lot of vendors put kits together with K-Motion springs because they are inexpensive. I've found these springs have a very limited service life (K-750's are a very common entry level roller cam spring).
K-Motion springs are what made me go to roller cam. The "flat tappet" cam came out with 3 flat lobes.
