How many running mid 10's on a T63?
NEARING
I have heard this turbo will do it but I'm thinking it MAY be eaiser and maybe less stressful on the motor to run say a GT67 or bb70
than to push 30psi on the 63.???? Or maybe not.???
Thanks.
I have seen low 11's high tens with my 63 4-bolt at around 124mph... I liked the turbo, but not as much as my 70.. ;) I run alot less boost with the 70 to get the numbers I saw with the 63..
Still nothing compares to my little te-44 I had....:D :D
Matt:cool:
what do you mean by that,i am thinking of going from a te44 to a lt70 or bb.
I mean that my old 44 was killer on the street..;) I had a stock converter and could smoke the tires for blocks..:D :D
I have seen low 11's high tens with my 63 4-bolt at around 124mph... I liked the turbo, but not as much as my 70.. I run alot less boost with the 70 to get the numbers I saw with the 63..
When you went to the 70 was that your only change? How much less boost do you run with the 70? I'm knocking on the door of a 10 second pass with a 63 and a stock long block.
The whole turbo thing confuses the crap out of me. I read a post like this and then think 70 goes faster than 63 at less boost therfore I should buy one and get that 10.xx, then you read about some dude with a 49 or 44 arleady going 10.xx. Then I start feeling like the little fat kid from South Park (Cartman) " I HATE YOU GUYS!, I HATE YOU GUYS SO VERY VERY MUCH!" :D
Jason
there is quite a difference between a T-63 and a T-63E.....lots of folks going 10's with the T-63E (same as TE-45A)
Craig Brown a local racer went 10.4 @ 128 with a PT-63 in his street car! Iron Heads and driven 2 hours back and forth to track.
I would go with the larger GTQ style unit like the 67.
I have run a 70 with out many problems.
I have a set of Mease headers waiting to go on now.
I'll also be going with a little more converter and switch from 27x10.5 to a 28x11.5 tire and open the dump on the hooker exh.
I may see 128mph but 10.60's is about all I can hope for I think.
She's too heavy(power EVERYTHING) for a 10.40 with this PT63 on 25-26 psi.
Not that mid 10's is slow for a car I've taken on 2-7 hr road trips.
