NY Twin Turbo
All the good stuff.....Times 2.
- Dec 10, 2014
Great thread.
SignUp Now!So it seems that the early on center came without cross bolts, the second version had cross bolted front/rear and the final version had all mains cross bolted.My on center doesnt have any cross bolted mains.
Yes. The cross bolted center versions had no dip stick provision.So it seems that the early on center came without cross bolts, the second version had cross bolted front/rear and the final version had all mains cross bolted.
If that is the order....it tells you they were fixing weaknesses with each version. GM don’t retool molds if it’s not necessary.So it seems that the early on center came without cross bolts, the second version had cross bolted front/rear and the final version had all mains cross bolted.
On center 153 with all mains being four bolt doesnt have dipstick either.Yes. The cross bolted center versions had no dip stick provision.
Dank From the photos it looked like you had cross bolted center but it was the motor mount bolt. Yours appears to be the same as my block and not the latest version. Still very cool though and thanks for sharingI thought there where more then 50 ON center blocks with cross bolted mains . Here is a couple pics of my bottom end that does have all 4 mains cross bolted![]()
Hard to tell without seeing them in person side by side but I'm curios if the casting are totally different or just different caps with additional machining to the block.If that is the order....it tells you they were fixing weaknesses with each version. GM don’t retool molds if it’s not necessary.
That's what I was told. I would like to know what the entire number means. The Gm rep/racer that mine came from said a lot of them went to a NC. He was at one of his GM dealerships in NC and my block was on the shelf in inventory..Mike just got a look at my 153s and my cross bolted block is also stamp on the front of the block with U415 so does this mean this block was also supposed to go to Busch Series when I got the block it was a brand new virgin blockView attachment 315799
