How much ALKY will she drink?
wordy1
Razor, in regards to your Progressive Kit for GN's/ About how much Denatured Alcohol can I expect to use during a normal 1/4 mile run? How much does the overfill bottle hold?
I have the stock MAP (Its a 2 Bar I think right?), do I need to use the 3 Bar MAP in your kit for it to work right?
Guess it depends how aggressive your having to spray the engine to keep your KR at zero. See if you run lets say 18-19 PSI you dont need as much as if you ran 28-29 PSI boost :D
Typically on a car running 23-25 PSI its about 1.5 ounces per second at WOT. A GN tank is 1 gallon. The Monte tank.. dunno
Yes on the 3 bar so it can tell the controller your over 15 PSI. 2bar stops reading at 14.7 PSI. So if your tuned to 22 PSI and the waste gate sticks.. the boost goes to 27.. the system knows to spray the engine harder.
Julio
I'd be using the overfill that comes with your kit. Also, where does the coolant go? IS there a separate chamber?
Yes there is a separate tank that comes with the kit.
Julio
It should bolt up to the wheel well on my Monte Carlo correct? If anything I may have to drill different holes, but the wheels wells are very similiar from what I've seen.
Off course thats why if you ordered a system from me, i'd order a tank for a Monte and with no doubt it will work.
HTH
Julio
An ALKY kit is first on my list, I already have an overfill bottle on the car now, they actually make a specific overfill for a monte that holds alky as well in a separate chamber? I find that hard to believe as the demand to run Alky in a Monte cannot be that high as most run V8's/
I think what Razor means is he would make a kit using the Monte Overflow tank. There is not a separate chamber within the overflow bottle for letting you have alky/coolant in the same tank. Razor sends a new overflow that you would use for the coolant. You'll love the kit! I just got my GN out of my parents garage for the first time in over a year (No room at my house, too many toys as it is) and I had forgotten how addictive 27psi is:eek: :biggrin: ! Nothing better than an electric dump pipe and a methanol kit:biggrin: . I only had 2 gallons of methanol left from when I put the GN away, and I'm about out!
