How much boost ?
Originally posted by stangbanger
I've been running over 30 psi for several years. I go to the track 3-4 times a year. My tank always contains Phillips B33. My combo is in the sig. The time listed was run in Bowling Green this year and the boost level was 35 psi. I run a RA 106 chip. I prefer more boost and less timing.......as you can tell. :D
Your combo is almost a carbon copy of Tim Stockwell's old combo, did you mean to follow his combo? It ran similar times to yours, w/ similar boost levels. That's awesome the motor can take that much boost. Do you know the timing in the chip? Does this Phillips do better than VP C16 or Sunoco in your opinion?
strike - I'm about 4 hours NE of you. I live in the Corinth area. NE MS has a few quick TRs, including the #1 and #3(me) qualifiers in TSS at this years Nats.
Live4 - I've read Stockwell's combo, but can't recall exactly what it was. It's probably not blind luck that the combos are similar. I have several friends in Ohio and I listen to what RA has to say. I think the timing in my 106 is 21 in 1st and 2nd and 19 in 3rd. I can't say how the B33 compares to other fuels. This is pretty much all I've used for the last 4 or 5 years. I can tell you this, the fuel I was running this year was left over from the drum I bought in the spring of 2001. Age doesn't seem to affect the fuel in my experience.
